Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Saving product + WPML issue
- This topic has 14 replies, 2 voices, and was last updated 6 years, 4 months ago by
- April 15, 2019 at 1:13 pm #57899
d-n-13
ParticipantHello wcloves,
in this week 2 times happened to me this issue.
Saving/Draft product on 2nd language might send product to main language
see screenshot 2 products all in default language : https://www.dropbox.com/s/xs9krhubg3b2mit/product%20move%20to%20main%20language.jpg?dl=0
the reason maybe because i was i change language in 2nd tab.
- April 16, 2019 at 5:32 pm #58166
d-n-13
ParticipantVideo : https://bit.ly/2v4nWIC
- April 18, 2019 at 7:50 am #58398
d-n-13
ParticipantThis is the 3rd time I have WPML issue with NORMAL product no PDF Voucher or anything, I tried to edit normal product on 2nd language and it copied\moved the main product from main language to 2nd language and both had same SKU it wouldn’t let me edit any of them or buy any of them until I change the SKU.
Screenshot attached.
I just started to open my website to real vendors, I cannot afford new extreme issues.
Thank You.
You must be logged in to view attached files. - April 18, 2019 at 8:24 am #58405
d-n-13
ParticipantThis reply has been marked as private. - April 21, 2019 at 5:35 am #58786
Well, I am not sure but as I see from error PDF Voucher not compatible with multi-currency perfectly, or it has some issues!
- April 21, 2019 at 6:58 am #58808
d-n-13
I am not using any multi-currency,
And PDF Voucher works fine in wp-admin translation product, only in wcfm it’s not working.
Actually I did another test after today’s update and same issue happened, main language product moved to 2nd language.
You must be logged in to view attached files. - April 21, 2019 at 7:45 am #58821
MemberDo you have test this with WCFM Ultimate 6.0.3 ?
If not, then please update and try once!
- April 21, 2019 at 10:11 pm #58893
- April 22, 2019 at 12:50 am #58900
d-n-13
ParticipantThis issue always happens when I use PDF Voucher, but it happened to me before without PDF Voucher (without pdf voucher is happened few times only and i don’t know how to reproduce the issue. But with pdf voucher it always happens with every translation attempt.), so maybe there is a common settings causing this issue ?
see screenshot attached of similar issue happened 2 weeks ago.
You must be logged in to view attached files. - April 25, 2019 at 5:34 am #59286
MemberStill we can not generate this, possibly it’s because of WPML setting.
We are checking this.
- April 25, 2019 at 9:15 pm #59462
d-n-13
I’ve did more testing after all new updates.
Good News:
1- Now I can translate with no issues.
2- Buying from EN or AR product both works and sends the next code.Bad News:
1- Checking purchased codes no longer shows data, (it was showing before the update) check attached screenshot.
2- Codes list isn’t updated in 2nd/translated language, (it suppose to remove purchased code) check 1st and 2nd screenshots showing main product purchased codes (1 & 2) removed, but not removed in translated product in 2nd screenshot.Thank You
- April 29, 2019 at 6:02 am #59813
Screenshots are missing, please give me those.
- April 29, 2019 at 9:26 am #59862
- May 1, 2019 at 12:21 pm #60188
MemberWell, I don’t think PDF Voucher plugin works like this with WPML.
In wp-admin are WooCommerce multi-lingual does not allow to edit any meta fields for translated products!
- May 1, 2019 at 12:22 pm #60189
MemberCan you please confirm from PDF Voucher plugin author, whether it’s fully WPML compatible?
- The topic ‘Saving product + WPML issue’ is closed to new replies.
