Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Sellers disappeared on the product page
- This topic has 4 replies, 2 voices, and was last updated 6 years, 8 months ago by
- March 26, 2019 at 12:18 pm #54542
Giovanni
GuestFirst of all thanks for having responded to me the previous time,
after the last update I have a problem with the vendors. They are present and I can see them in the manager but during the insertion of the products on the product page there are no sellers, I have to reassign them manually from woocommerce where they are present and everything works correctly. Obviously then it works and everything is well connected in the online version, the vendors disappeared only in the product page of WCFM.
How i can put the follow store button in the store page and in the tab vendor on the product page?
Another question how can I put 2 Stores per row back on the vendor list?
Thank you so much - March 28, 2019 at 9:43 am #54899
– Can you please show me screenshot for this.
– You have to specify “per_row=2” with stores short code. Please check this for details – https://docs.wclovers.com/store-list/
- March 28, 2019 at 9:49 am #54902
Giovanni
GuestThis reply has been marked as private. - March 28, 2019 at 9:53 am #54908
Giovanni
GuestThanks for the reply, you can simply see among the vendors, and then add a new product, you will see that they do not appear but if you go to woocommerce> product the vendors are there as there are also in the online version the correct storefront with all the products related to each vendor.
- March 28, 2019 at 1:47 pm #54996
– Where it’s not appearing? Hope it’s not caching issue!
- The topic ‘Sellers disappeared on the product page’ is closed to new replies.
