wcfm-santa
The New Year has begun! Avail upto 25% OFF on WCFM Addons.
01Day 07Hrs 49Min 20Sec
Sellers display
Viewing 3 reply threads
    • #19027
      DENIS
      Hi. Can I get a consultation in Russian ? I have a problem with the display of Sellers on the tab on the part of the Administrator. When clicked, it shows that such a page does not exist although previously the tab worked and showed the existing sellers. How can I fix this problem ?
      Screenshot https://prntscr.com/idqoay
      Screenshot 2 https://prntscr.com/idqodz
    • #19028
      DENIS
      Installed WooCommerce Frontend Manager
    • #19029
      This is quite strange. Between, which multi-vendor plugin you are using in?
      Are you comfortable enough to allow me to check your setup once?
      Then please contact us directly at here – https://wclovers.com/contact-us/
    • #19173
      It’s resolved.
      Issues was due to miss-configuration of pages.
  • The topic ‘Sellers display’ is closed to new replies.
