Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Seperate Invoices For Vendors
- This topic has 6 replies, 2 voices, and was last updated 6 years, 3 months ago by
- May 3, 2019 at 1:48 pm #60491
Fredrick
GuestWhen there is an order from more than one vendor I get an email with the invoices attached from each vendor order but in admin panel I only get one invoice for the whole order, is there a way like Dokan to create subfolders in the admin panel with the main order invoice and then under it a separate invoice for each vendor ordered from?
- May 3, 2019 at 4:38 pm #60519
Which multi-vendor plugin you are using right now?
- May 5, 2019 at 10:54 am #60660
Fredrick P Miller
GuestI am using WooCommerce Multivendor Marketplace with WooCommerce Frontend Manager – Ultimate
- May 5, 2019 at 8:37 pm #60774
Thanks, well you may check all vendor orders’ invoice from WCFM Admin Dashboard -> Vendors -> Vendor Manager -> Order section
- May 6, 2019 at 12:40 pm #60910
Fredrick P Miller
Guestok,I see. I usually do it from admin panel. I will start using WCFM to do it. Thanks
- May 6, 2019 at 12:51 pm #60915
Fredrick P Miller
GuestOk, I tried this but this doesn’t accomplish what I need. I need a separate invoice for each order that has muti vendor orders. Am I missing something? When there are multi vendor orders there is an email sent that includes each vendor invoice .pdf, the problem is it sends an invoice even if the order is cancelled so I cannot rely on this method. Any ideas? Thanks
- May 9, 2019 at 8:06 am #61305
– Are you receiving store specific invoice in cancel order email? Or it’s total order invoice!
You may adjust this from wp-admin -> WooCommerce -> PDF Invoices -> Document -> Invoice
- The topic ‘Seperate Invoices For Vendors’ is closed to new replies.
