Seperate Order for each vendor in a single checkout
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Feature Request Seperate Order for each vendor in a single checkout
Viewing 1 reply thread
    • #64151
      owen
      I wanted to know if it is possible to seperate the order for each vendor in a single checkout.
      In other words, unique order number per vendor in a cart.
      This will allow vendor to change order status only for their products not change the whole order when contain other vendor products.
    • #64856
      – Well, for this separate Order No. not require. You just have to disable “Order Sync” option from WCFM Admin Setting -> Marketplace Setting – https://ibb.co/4mN6KRz
