Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › SET PERMANENT HIDDEN SOME FIELDS IN PRODUCT PUBLISHING PAGE, after publishing
- This topic has 8 replies, 2 voices, and was last updated 6 years, 7 months ago by
- December 8, 2018 at 8:53 am #39327
Lwifunyo Mangula
ParticipantHi sir!
hope you are fine!After pre-setting and hide some unncessary fields in product publishing page using the plugin you have provided here
https://wclovers.com/forums/topic/how-can-i-hide-unnecessary-fields-in-product-publishing-page-and-preset-values/after just publishing product, those hidden fields they seen again. How to permanent hide them in product publishing page even after publishing a product?
thanks in advance
- December 8, 2018 at 9:29 am #39328
Please use this instead -> https://drive.google.com/file/d/1JaJzruPFMUzGJ9Otp31IQJ_amn-8_iL9/view?usp=sharing
- December 8, 2018 at 10:06 am #39330
Lwifunyo Mangula
ParticipantSir,
in product publishing page for bookable product,
there is a tab for resource.in resource tab i can only add *Title, Base Cost and Block Cost* but i cant add number of resource which im creating unless i go to booking menu and create manually resource there.
but
i have found it is difficult for vendors to have that long process which is difficult for new vendors who are still not familira.How much cost will it for the job if i want *number of resource available to be created and edited at the resource tab* without vendors going at other menu to edit resource again. This means that adding one new field in resource tab which will a number field to set number of reousrce available?
- December 8, 2018 at 10:25 am #39331
I am a bit confused with your requirement.
Vendor may use predefined resources or add resource at the time of adding product -> https://ibb.co/F5TKC8D
Then what else you want to change here and why you think it’s wrong process?
- December 8, 2018 at 10:40 am #39332
Lwifunyo Mangula
ParticipantYes vendor can add resource, but to set available quantity he/she must go to another menu, this in some cases become long process.
what im asking is to add a new number field A RED COLOUR FIELD I HAVE INDICATED IN A PICTURE ATTACHED, which will help much a process become more simple for vendirs to add quantity of resources at the same tab.
it make a process simple and non complicated
You must be logged in to view attached files. - December 8, 2018 at 10:46 am #39334
Lwifunyo Mangula
Participantavailable quantity is the fields set at the othe menu for booking manage fields
You must be logged in to view attached files. - December 8, 2018 at 11:51 am #39338
I understand your requirement now, thanks for all details.
Well, this will cost you $30 USD
- December 10, 2018 at 10:11 am #39507
Lwifunyo Mangula
ParticipantOkey. Thanks. Let we see it.
- December 10, 2018 at 10:28 am #39508
MemberSure!
- The topic ‘SET PERMANENT HIDDEN SOME FIELDS IN PRODUCT PUBLISHING PAGE, after publishing’ is closed to new replies.
