Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Setting up minimum qty and increments for products in vendor's dashboard
- This topic has 4 replies, 3 voices, and was last updated 5 years, 4 months ago by
- April 21, 2020 at 5:55 am #121194
anton
ParticipantHi guys,
In the older forum request I found this plugin suggested to do this which we installed:
“By Product Quantity: – Use this plugin for the purpose – https://woocommerce.com/products/minmax-quantities/
and I see those fields in WooCommerce: https://www.screencast.com/t/VKLmVdpMp
but I do not see those fields in WC vendor’s dashboard: https://www.screencast.com/t/JUyMk9Td0
how can I add those fields there?
Thanks - April 21, 2020 at 8:34 am #121230
anton
ParticipantI just ordered and installed WCFM Ultimate and see the min and incremental qty in the vendor dashboard now.
thanks for the great system. - April 22, 2020 at 1:58 pm #121689
KeymasterGlad it worked well for you 🙂
- April 26, 2020 at 12:20 pm #123189
moffzar
ParticipantHi, I can the Min/Max quantity setting at the back end but don’t see it in the vendor dashboard.How to set it up?
- April 26, 2020 at 12:40 pm #123195
I assume you are using https://woocommerce.com/products/minmax-quantities/ plugin for this.
WCFM provides this third-pary plugin compatibility via WCFM Ultimate addon – https://wclovers.com/product/woocommerce-frontend-manager-ultimate/
If you already have WCFM Ultimate, please install and activate that.Looking forward to helping you.
