Several "order completed" mail per order
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Several "order completed" mail per order
Viewing 9 reply threads
    • #92767
      CommunityCorals
      since update there is one completed mail send per order item. This spams the customers and feels quite unprofessional. Any way to consoidate this to one mail?
      Dominique
    • #92769
      CommunityCorals
      P.S. It´s not the “order completed mail” but the “customer note mail” that causes the issue. (woocommerce/templates/emails/customer-note.php)
    • #93537
      OK, but when this email is triggering? When vendor adding not to an order or for some other cases?
    • #93602
      CommunityCorals
      I just saw that behaviour on order status change to “completed”. Not sure if there are even more cases where this happens.
    • #94024
      Do you have any plugin to your site to manage order status?
    • #95914
      CommunityCorals
      No nothing like that. Please feel free to check my staging site. Am I the only one with this issue?
      Just to make sure that everything is clear: I am using order status unsync and I am talking about commission status change rather than order status change.
      BR
      Dominique
    • #97948
      SebastianFloKa
      exactly the same issue here …
    • #98603
      We are debugging this.
    • #101696
      SebastianFloKa
      with the latest update it looks like you solved this issue – thanks a lot.
      For documentation, here the code for the child-theme functions.php:
      add_filter( ‘wcfm_is_allow_itemize_notification’, ‘__return_false’ );
      Just to mention: the code works only with the wording “itemize”. Don’t use the expected “itemwize”!
      Thanks a lot for fixing this.
    • #106016
      Right, this is the filter – add_filter( 'wcfm_is_allow_itemize_notification', '__return_false' );
  • The topic ‘Several "order completed" mail per order’ is closed to new replies.
