Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Several places need to be translated
- This topic has 5 replies, 3 voices, and was last updated 6 years, 9 months ago by
brahim01.
- May 31, 2019 at 2:19 am #65111
Hussain_Safafeer
I am using WPML to translate your plugin and 99% of has been translated.
But maybe the places in the attached pictures, are forgotten to have a way for them to get translated.So, please can you look at them and find a way to make them translatable.
Regards.
You must be logged in to view attached files. - May 31, 2019 at 10:27 am #65174
brahim01
ParticipantHi Hussain,
I am also translating the wcfm throught wpml.
what method are using? string translation? or edit the pot file directly?
Best regards,
Ps: it will be great if we can exchange or pot files and sure probably you have the same issue in other plugins. So let’s work together to do it.Brahim
- May 31, 2019 at 7:54 pm #65272
Hussain_Safafeer
Participantthe translations are attached.
Regards.Attachments:
You must be logged in to view attached files. - May 31, 2019 at 9:32 pm #65313
– Sure, we will add those in next update.
- May 31, 2019 at 10:21 pm #65332
Hussain_Safafeer
ParticipantThank you very much.
- June 1, 2019 at 1:03 pm #65424
brahim01
ParticipantThank you Hussain for Sharing the tanslations
