Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Shipping deactivates itself
- This topic has 1 reply, 2 voices, and was last updated 6 years ago by
- May 6, 2020 at 5:25 am #127205
alexdezi
ParticipantHello!
Everytime a shop gets edit (by me or a vendor), somehow shipping gets deactivated. This is becoming a real issue. I am good with me checking on the frontend if in the sidebar the shipping shows – so I know it’s activated. But I am losing contorl over it, when someone else is editing the shop.
Can you please have a look into this?Thank you!
- May 6, 2020 at 1:20 pm #127313
It might be due to a conflict with another plugin or some custom code (more probable cause). To debug this, first disable all your custom code.
If you make your changes via child themes functions.php, then changing theme, temporarily, is a easy way to do so. If you use a code snippet plugin then disable it.
If the problem persists, then you can check this with only WooCommerce and WCFM plugins activated.
Let me know how it goes.
Thank You!
- The topic ‘Shipping deactivates itself’ is closed to new replies.
