Shipping Plug in
Viewing 4 reply threads
    • #57193
      ssadowski6689
      Hello!
      I would like to use a shipping plug in so that my vendors are able to create and print shipping labels directly through the marketplace site. Is there a way to do this with WCFM – Ultimate? If so, what are my best options for integration?
      Sarah
    • #57476
      Well, WCFM Ultimate already has Shipping Label print option, is this not working for you ?
    • #57486
      ssadowski6689
      Let me just clarify to make sure we are talking about the same capability. I want the vendors to be able to print of, say USPS, UPS, or Fedex labels that are printed through the website, based on the customer’s shipping address. If that is a capability of WCFM Ultimate, I completely missed it. If you could direct me to the correct document or tutorial for setting that up, it would be much appreciated.
      Sarah
    • #57534
      Understand. But which UPS plugin you are using?
      You require this plugin, only this works for multi-vendor sites – https://www.pluginhive.com/advanced-shipping-for-woocommerce-multi-vendor-plugin/
    • #57905
      Sarah
      Perfect! Thank you!
  • The topic ‘Shipping Plug in’ is closed to new replies.
