Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Delivery › Shop Problem
- This topic has 3 replies, 2 voices, and was last updated 5 years, 11 months ago by
Craig.
- March 13, 2020 at 9:12 pm #111471
www.tresfrais.fr
ParticipantHello
i love your pluging and i think i will purchase the ultimate
I have a problem, on the shop page the categories are displayed above the map.I need a solution to differentiate delivery methods by membership category.
first category can sell without delivery and second category can sell and deliverThank you very much
You must be logged in to view attached files. - March 13, 2020 at 10:28 pm #111474
Craig
Participanthttp://www.tresfrais.fr with formatting/styling concerns you should first test your layout with the “storefront” theme which is fully compatible with these plugins.
That will help eliminate where the issue is because if it is a theme design issue then you would need to look at some coding changes/customization to your theme which the plugin developers aren’t really responsible for. - March 14, 2020 at 5:23 pm #111591
www.tresfrais.fr
ParticipantThank you, i will try it. what do you think about the second problem?
best regards
- March 15, 2020 at 10:18 pm #111692
Craig
ParticipantRegarding your other request have you looked at the options that you can turn off/on under the “capabilities” section of the “Groups” tab? These groups you assign to your membership types.
There is a “shipping panel” in there but I think that would only hide the shipping inside the product listing editor based on the membership type.
I’m not sure if there is one that would hide the shipping tables from the vendor settings which is what I think you are trying to do?
