Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Simple Auction plugin not working on Vendor Store
- This topic has 4 replies, 2 voices, and was last updated 6 years, 6 months ago by
- September 8, 2019 at 10:58 pm #80753
poptastico
ParticipantHello
I bought the Simple Auction plugin as indicated here as compatible plugin but after installed I couldn’t see on Vendor Store.
It appears only on WP Core products.
How can I make it available for Vendor Store?
Regards
Kelson
- September 9, 2019 at 1:21 pm #80825
Which auction plugin you are using?
WCFM compatible with these –
https://codecanyon.net/item/woocommerce-simple-auctions-wordpress-auctions/6811382
https://yithemes.com/themes/plugins/yith-woocommerce-auctions/Between, what is your WCFM Ultimate (https://wclovers.com/product/woocommerce-frontend-manager-ultimate/) version? It’s essential for auction product type to work with WCFM.
- September 9, 2019 at 5:10 pm #80858
poptastico
I am using the “woocommerce simple auctions” plugin
https://codecanyon.net/item/woocommerce-simple-auctions-wordpress-auctions/6811382I am using the free version. Is it necessary the Ultimate version? How can I test on free version?
Kelson
- September 9, 2019 at 6:43 pm #80897
poptastico
ParticipantOk, I see that’s only available for Ultimate version.
I just bought it, hope it solves the Auction issue.Do I need to uninstall the free version in order to install the Ultimate?
Will I loose all stores?
And if one day I decide for the Lifetime version? will loose stores?Thanks
Kelson - September 14, 2019 at 10:03 pm #81622
Will I loose all stores?– NO, WCFM Free will be always there, it’s core for all WCFM addons.
– Not at all, your license will be upgraded.Thank You
