Simple Auctions – Proxy on by default
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate Simple Auctions – Proxy on by default
Viewing 2 reply threads
    • #28773
      Pitz
      Just a small request – I was going through settings after updating the WooCommerce Simple Auctions Plugin and wanted to use “Set proxy auctions on by default” I believe it’s fairly new in settings because I don’t remember it before.
      Anyway could you have WCFM use the setting from there, so that if it is checked, it will be checked on by default when a vendor lists an auction?
    • #28801
      We will definitely add this in WCFM Ultimate next update.
    • #30517
      It’s already implemented in WCFM Ultimate 5.0.2
  • The topic ‘Simple Auctions – Proxy on by default’ is closed to new replies.
