Single Product- Store Name (Elementor)
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Single Product- Store Name (Elementor)
Viewing 4 reply threads
    • #88019
      herman-0569
      Hi guys,
      First of all, WCFM is amazing!
      So quick question, doing a single product design with Elementor but it seems the WCFM Integrated options for Store Name do not link to that Vendor? How do I create the store name so that it is hyperlinked to the store or is it a limitation with your WCFM Elementor Plugin?
      The Store Name Elementor element from your plugin when put on page, puts it there as a Title, I adjusted this with the dynamic field to display store name, but it only pulls the store name so doesn’t hyperlink it.
      Any assistance will be highly appreciated 🙂
    • #88421
      – Well, this addon is not useful right now to add “Sold By” text for single product page.
      You may use “Vendor Store:Info” widget for the purpose – https://ibb.co/MpPsjtq
      Or, may use short codes – https://wclovers.com/knowledgebase/wcfm-marketplace-widgets-short-codes/
    • #88505
      tasost
      So there is no shortcode to display with elementor store name in archive products or single product page?
    • #88565
      herman-0569
      Thank you, will give it a try and let you know if it worked.
    • #89067
      tasost
      That worked!!!
  • The topic ‘Single Product- Store Name (Elementor)’ is closed to new replies.
