Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Single select
- This topic has 5 replies, 4 voices, and was last updated 6 years, 1 month ago by
- January 22, 2020 at 7:40 pm #103223
GutM
ParticipantHow can I make when vendors adding products can only select single attribute option from desplegable?
- January 29, 2020 at 9:00 pm #104575
Your query isn’t clear. Can you please explain what you want to achieve? If possible a snapshot of the section would be great.
Thanks - February 6, 2020 at 3:24 pm #105764
add_filter( 'wcfm_attribute_limit', function( $limit ) { return 1; });Add this code to your child theme’s functions.php
- February 9, 2020 at 3:27 am #106245
badianafaa
ParticipantHello, this snippet work but only alone, beacause when i want to make all attributes required with this snippet :
add_filter( 'wcfm_product_custom_attributes', function( $taxonomy_fields, $att_taxonomy ) { if( isset( $taxonomy_fields[$att_taxonomy] ) && isset( $taxonomy_fields[$att_taxonomy]['options'] ) ) { if( isset( $taxonomy_fields[$att_taxonomy]['options']['is_active'] ) ) { $taxonomy_fields[$att_taxonomy]['options']['is_active']['custom_attributes'] = array( 'required' => 1, 'required_message' => 'Attributes are required' ); } if( isset( $taxonomy_fields[$att_taxonomy]['options']['value'] ) ) { $taxonomy_fields[$att_taxonomy]['options']['value']['custom_attributes'] = array( 'required' => 1, 'required_message' => 'Attributes are required' ); } } return $taxonomy_fields; }, 50, 2);, the limit 1 snippet doesn’t work anymore. Is it possible to make the 2 snippets work correctly together ?
- February 9, 2020 at 3:44 am #106246
badianafaa
ParticipantIdem with this snippet :
add_filter( 'wcfm_product_custom_attributes', function( $taxonomy_fields, $att_taxonomy ) { if( isset( $taxonomy_fields[$att_taxonomy] ) && isset( $taxonomy_fields[$att_taxonomy]['value'] ) ) { $attributes = $taxonomy_fields[$att_taxonomy]['value']; $wcfm_attributes = array(); if( !empty( $attributes ) ) { foreach( $attributes as $acnt => $wcfm_attribute ) { $wcfm_attributes[$acnt] = $wcfm_attribute; $wcfm_attributes[$acnt]['is_active'] = 'enable'; $wcfm_attributes[$acnt]['is_visible'] = 'enable'; } } $taxonomy_fields[$att_taxonomy]['value'] = $wcfm_attributes; } return $taxonomy_fields; }, 50, 2);Is it possible to make that 3 snippets work correctly together ?
- February 10, 2020 at 7:23 pm #106513
KeymasterHello,
Please use the following snippet for that –add_filter( 'wcfm_product_custom_attributes', function( $taxonomy_fields, $att_taxonomy ) { if ( isset( $taxonomy_fields[$att_taxonomy] ) && isset( $taxonomy_fields[$att_taxonomy]['value'] ) ) { $attributes = $taxonomy_fields[$att_taxonomy]['value']; $wcfm_attributes = array(); if ( ! empty( $attributes ) ) { foreach ( $attributes as $acnt => $wcfm_attribute ) { $wcfm_attributes[$acnt] = $wcfm_attribute; $wcfm_attributes[$acnt]['is_active'] = 'enable'; $wcfm_attributes[$acnt]['is_visible'] = 'enable'; } } $taxonomy_fields[$att_taxonomy]['value'] = $wcfm_attributes; } if ( isset( $taxonomy_fields[$att_taxonomy] ) && isset( $taxonomy_fields[$att_taxonomy]['options'] ) ) { if ( isset( $taxonomy_fields[$att_taxonomy]['options']['is_active'] ) ) { $taxonomy_fields[$att_taxonomy]['options']['is_active']['custom_attributes'] = array( 'required' => 1, 'attrlimit' => 1, 'required_message' => 'Attributes are required' ); } if ( isset( $taxonomy_fields[$att_taxonomy]['options']['value'] ) ) { $taxonomy_fields[$att_taxonomy]['options']['value']['custom_attributes'] = array( 'required' => 1, 'attrlimit' => 1, 'required_message' => 'Attributes are required' ); } } return $taxonomy_fields; }, 50, 2 );Thanks
