Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Groups & Staffs › Some of Dashboard -> Capabilities override Groups Capabilities.
- This topic has 5 replies, 2 voices, and was last updated 8 years, 3 months ago by
- June 19, 2018 at 2:27 am #25082
d-n-13
ParticipantHello wcfm support team,
Some capabilities override groups & staff capabilities and some doesn’t, it is a bit confusing.
Check screenshot attached
1- Disabling “Manage Products” will result all groups to not be able to manage products, **Product tab will not show**
2- Disabling “Adding Products” will NOT result all groups to not be able to add products, *Groups can still add products* This is the good way it should be.Number 2 is preferred, it is also good option to not allow new vendors to not be able to sell without buying a membership (if vendor registered using dokan registration form or plugin other forms).
- June 19, 2018 at 11:10 am #25117
Yeah right. Manage Products and Add Products at Global capability totally disabled Product capability for Vendor user role.
Here is a general suggestion for you – if you are using Groups then keep ON all capabilities at Global Capability settings.
Number 2 is preferred, it is also good option to not allow new vendors to not be able to sell without buying a membership (if vendor registered using dokan registration form or plugin other forms). – If you want achieve this then just set “Product Limit -> 0” at Global Capability setting.
- June 20, 2018 at 6:15 am #25149
d-n-13
Setting Product Limit -> 0 will give vendor (Unlimited Products)
See vid I made : https://youtu.be/hgyrX6LZuI4
- June 22, 2018 at 5:49 am #25228
Understand. Set “1989” as Product Limit.
- June 22, 2018 at 8:25 am #25239
d-n-13
this is so specific number.. it worked tho! so perfect for me now.
This topic’s problem is resolved for me.
Thanks a lot!
- June 22, 2018 at 10:45 am #25252
Yeah right.
Actually, in PHP 0 and empty returns same results for some PHP versions. So, we have kept this reserve number.
- The topic ‘Some of Dashboard -> Capabilities override Groups Capabilities.’ is closed to new replies.
