Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Some widget not displayed in sidebar
- This topic has 5 replies, 2 voices, and was last updated 5 years, 4 months ago by
Ramamurthy Krishnan.
- April 29, 2020 at 10:21 pm #124757
t.bry
I’m trying to add widgets in the single product sidebar like vendor location and vendor policies but they don’t show up.
Others widget like Vendor open and close times work fine. I’ve tried with storefront as my default template is ocean, same result.
Do you know what could happen ?thanks
- April 29, 2020 at 11:21 pm #124779
Ramamurthy Krishnan
Vendor Store widgets will only work in vendor store details page sidebar. It displays information of the specific vendor in store details page.
- April 29, 2020 at 11:21 pm #124780
Ramamurthy Krishnan
- April 30, 2020 at 2:54 pm #125013
t.bry
Thanks. I’ve found a trick using the html widget and using these options :
[wcfm_store_info id=”” data=”store_address”][wcfm_store_info id=”” data=”store_phone”]
[wcfm_store_info id=”” data=”store_location”]
and it works !
- April 30, 2020 at 3:54 pm #125026
t.bry
ParticipantDo you think I could do the same for the Shipping Policy and if yes how (what is the ‘data’ to use ?
- April 30, 2020 at 11:56 pm #125191
Ramamurthy Krishnan
All the “data” parameter values available for “wcfm_store_info” shortcode are mentioned in this link: https://wclovers.com/knowledgebase/wcfm-marketplace-widgets-short-codes/
