something broken on wcfm-products-manage
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate something broken on wcfm-products-manage
Viewing 7 reply threads
    • #19888
      valerio
      Hi all,
      The plugin seems to work fine on my site except for the edit product page (product edit), where something seems weird.
      First: the wp admins top bar, always loading in the other sections, disappear when entering in a specific product to modify.
      Second, most problematic, the bottom part of the page (products meta options controls) seems to be broken: I cannot click on the left side tabs such as “inventory”, “booking options”, etc…
      Everything seems to be caused by a js conflict… so
      1. I changed to the default wp template;
      2. I disabled all the unecessary plugin;
      But nothing changed.
      Any idea about that?
      You’ll find the screenshot attached.
      Valerio
    • #19894
      Bingal
      Keymaster
      Can you please be sure, this page has no JavaScript error?
      Please use Google chrome browser console for checking this.
    • #19895
      valerio
    • #19897
      Bingal
      Keymaster
      Thanks for the credentials, i am just looking into this.
    • #19898
      Bingal
      Keymaster
      You are right, there is no errors and it works perfectly for me.
      Can You please clear cache and take a try!
    • #19899
      Bingal
      Keymaster
      Well, I am just getting an issue when trying to edit an Product.
      This error due to your WC Bookings plugin, it’s quite old (version 1.10.1) and it’s no way compatible with late WC . and WCfM.
      Please update your WC Bookings and there will be no issues at all.
      Please know me is this resolve your issue or not!
    • #19917
      Linda Benefield
      When I got the Ultimate, my products manager for my vendors stopped showing up in the tabs. I deactivated the ultimate and just used the regular one and it started working again. I also had the memberships and groups and staffs. I am not sure what is going on. I use WC Marketplace plugin for my vendors.
    • #19954
      Bingal
      Keymaster
      I am closing thread for now.
      Both the issues has been resolved, it was noting but some configuration issues.
  • The topic ‘something broken on wcfm-products-manage’ is closed to new replies.
