Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Stock Syncing
- This topic has 2 replies, 1 voice, and was last updated 7 years, 2 months ago by
sdel_nevo.
- July 26, 2019 at 3:46 pm #74032
sdel_nevo
ParticipantHi Guys
is this possible to do?
I am in desperate need for a way for vendors products stock levels to sync with there existing woocommerce store if they have one
for example
if a vendor already has a woocommerce store, as soon as a product is sold or the stock level changes on their own Webstore this needs to sync this to the vendor’s store products on our marketplace
if a vendor sells a product in our marketplace, this stock level needs to be synced back to the vendors Webstore
this would allow for two way syncing between the vendors own webstore and our marketplace and visa Versa
is this possible, do you know of a plugin that would be compatible
Steve
- July 29, 2019 at 9:34 am #74342
sdel_nevo
ParticipantHi Guys
would it be possible to integrate this plugin
https://codecanyon.net/item/stock-synchronization-for-woocommerce/19425704?ref=InkThemes
so that it would work for individual vendors, could a vendor have there own stock synchronisation tab, where they can put the required details to only update the stock levels of there products?
if so this would be brilliant, I am desperately looking for a solution as currently, my vendors do not appear to be keeping their vendor store and their woocommerce store inventory in sync
Steve
- September 3, 2019 at 9:13 am #79773
sdel_nevo
ParticipantHi Guys
is it possible to integrate this plugin?
Stock Synchronization for WooCommerce found here https://codecanyon.net/item/stock-synchronization-for-woocommerce/19425704?ref=InkThemes
that would be brilliant
Steve
- The topic ‘Stock Syncing’ is closed to new replies.
