Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Store Display Settings
Tagged: store dashboard, store display, store settings, store style
- This topic has 3 replies, 2 voices, and was last updated 6 years, 4 months ago by
- May 13, 2019 at 4:02 pm #62092
pdishman
There does not seem to be the settings I need to accurately display my store. Please see attached. Which setting do I change to change the inquiry button colors and background on hover? There doesn’t seem to be an option for that. Also you’ll notice that the social buttons are blank, unless I hover over them, then they are blue. You’ll see by my attached store display settings that I don’t seem to have options to fix these.
Thank you for your help!
You must be logged in to view attached files. - May 16, 2019 at 2:55 pm #62504
https://wclovers.com/wp-content/uploads/2019/05/Store-Display.png
– Please change “Header Icon” color to something else that white.
– Buttons background color same as “Header Text” color
- May 16, 2019 at 3:53 pm #62519
pdishman
ParticipantYes, I figured that out – it was confusing because the header icons should not include the social icons. I want the header icons to be white. I want the social icons to be a different color – those two need to be separate!
Also, you didn’t respond to the buttons on the store banner image – inquiry, chat now and follow – there is no apparent setting to change the colors for those buttons…
- May 17, 2019 at 4:10 pm #62671
– I mentioned you this for buttons background color.
- The topic ‘Store Display Settings’ is closed to new replies.
