Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Store hours not shown
- This topic has 3 replies, 2 voices, and was last updated 5 years, 4 months ago by
- May 11, 2020 at 2:21 am #129324
megafas
ParticipantI put the schedule of each providers and the Widgets, but no results are shown in the seller’s store
- May 11, 2020 at 10:07 am #129423
Please confirm you have done the following steps-
1. You have added the widget Vendor Store: Opening/Closing Hours to the Vendor Store Sidebar
2. You have Store Hour option enabled under the Settings section of WCFM Dashboard (admin user) >> Capability page
3. Your vendors have Enable Store Hours settings checked.
4. Vendors have set both Opening and Closing time correctly
**After step 3 you should at least see the widget title Store Hours on store sidebar.
Let me know how it goes.
Thank You! - May 11, 2020 at 3:32 pm #129530
megafas
ParticipantOk, the title appears on the web.
- May 12, 2020 at 12:15 pm #129913
KeymasterSo that simply means the store page you are visiting keep their Store hours disabled. Please tell them to check Enable Store Hours option from Settings >> Store Hours like this- https://imgur.com/8RHk8kX and set their opening hours in HH:mm AM/PM format.
Thank You!
