Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Store informations missing on shop header
- This topic has 12 replies, 3 voices, and was last updated 6 years, 8 months ago by
- August 22, 2018 at 11:46 pm #29262
hkgemnet
ParticipantI have added store address but updates are not shown in shop headers which is coming from wc vendors.
As your plugin is wc vendors compatible i believe store informations should show up on shop headers. - August 23, 2018 at 10:44 am #29335
Yeah off course.
We are checking this.
Between, are you using WC Vendors Pro?
- August 23, 2018 at 1:37 pm #29357
hkgemnet
GuestYes. Wc vendors pro.
- August 23, 2018 at 1:40 pm #29358
hkgemnet
ParticipantYes. Wc vendors pro.
- August 24, 2018 at 5:07 pm #29551
It’s WC capability issue, we already found this issue.
We will resolve this in WCFM next update.
- August 24, 2018 at 6:22 pm #29588
hkgemnet
ParticipantAny rough estimation on how many days it may take?
And what will be the updated version no.? - August 24, 2018 at 6:53 pm #29603
Next update will be there early next week.
New versions will be –
WCFM 5.0.4
WCFM Ultimate 5.0.1Thank You
- August 27, 2018 at 6:06 pm #29873
hkgemnet
ParticipantStill no luck.
Updated already. - August 29, 2018 at 4:38 pm #30113
Can you please do a simple test?
Update that vendor user from wp-admin -> Users area and take a look are those information updating or not!
- August 30, 2018 at 6:45 pm #30246
hkgemnet
Participant“I have added store address but updates are not shown in shop headers which is coming from wc vendors.
As your plugin is wc vendors compatible i believe store informations should show up on shop headers.”
– This is what i wrote while creating this topic(assuming support ticket as paid customer).The header part which is coming from wc vendors on vendors single page
is not showing address (as wcfm address and wc vendors addresses are not same).As wcfm is compatible with wc vendors
Shouldn’t it display the address (saved from store manger of wcfm) into shop header of wc vendors?User informations are updating quiet well.
Talking about wc vendors shop header. - September 3, 2018 at 6:11 am #30604
Well, this also resolved.
You had disabled “Brand” from capability, then how you were adding “Address” for vendors?
I have enabled and added Address for the vendor and it’s showing perfectly at their Store Header – https://gemxnet.com/dealers/user-vendor-store1/
Just to mention, if you think all user/member plugin can manage vendors then you are thinking wrong. Vendor is a very special user type and very few plugins has support for this.
Most importantly, please never manipulate vendor user role using “User role editor” plugin, this plugin breaks vendor users and there is no way to revert this.
- September 3, 2018 at 5:29 pm #30696
hkgemnet
ParticipantGREAT SUPPORT.
CHEERS.Highly Appreciate.
- September 3, 2018 at 6:19 pm #30702
MemberYou are welcome 🙂
If you get a chance then please add a review foe me – https://wordpress.org/support/plugin/wc-frontend-manager/reviews/
- The topic ‘Store informations missing on shop header’ is closed to new replies.
