Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Store Invoice & Commission layout + translation issue.
- This topic has 3 replies, 2 voices, and was last updated 6 years, 11 months ago by
- September 27, 2018 at 3:36 pm #32702
d-n-13
ParticipantHello good wcfm team,
I finally got back from long business trip and now I can do real testing again.
There is invoice problem I am facing and I’m going to list it down below.
A) Store Invoice :-
1- Store Image appears too large in the invoice, I tested 2 images both are large (in both en & ar languages) : https://www.dropbox.com/s/8hrurdtb31gsas2/invoice-wcfm%20.pdf?dl=0 & https://www.dropbox.com/s/dumc4fuo6b23xer/ar2%20store-invoice.pdf?dl=0
2- Invoice Number always empty, is it support to be empty ? https://www.dropbox.com/s/3poj7b3dg2a1q3q/invoice%20number.JPG?dl=0
3- Text cannot be translated in wcfm store invoice such as (Order Number: Invoice Number: Order Date: …etc) even tho it is translated in wc normal invoice like here : https://www.dropbox.com/s/qbjq2ios49u6b5r/invoice%20translation.JPG?dl=0
B) Commission Invoice :-
1- Layout isn’t appearing correctly in both en & ar. https://www.dropbox.com/s/zib3ga63ai7sgnq/invoice-6967%20commission%20invoice.pdf?dl=0 & https://www.dropbox.com/s/quxa1mffzpf7c0f/ar2%20commission%20invoice-6973.pdf?dl=0
Important Note 1 : These issue appears in both en & ar.
Important Note 2 : These issue appears even if I disable “mPDF” library, looks like it is not related.
Feature Request 1 : Can you add the ability for admin see the commission invoice too ?
Thank You WCLovers
- October 1, 2018 at 6:46 am #32950
1. It’s due to mPDF, resolved in WCFM Ultimate 5.1.2 (https://www.4.wegospace.com/cnt/uploads/wcfm/vendor_invoice/37/2018/10/invoice-000024.pdf)
2. Resolved in 5.1.2
3. I am getting right view – https://ibb.co/cqLjpK
Hope you are testing here – https://www.4.wegospace.com/ and all WCFM U is at latest version.
- October 1, 2018 at 4:54 pm #32982
d-n-13
Yes i’m testing on https://www.4.wegospace.com/
Last test I did after last update everything looks 95% good,
Customer will resieve email with 2 invoices, invoice from vendor and invoice from admin/website
invoice from vendor looks okay with no issues here : https://www.dropbox.com/s/g7e2c7qp3q6oysl/invoice-000001%20store%20invoice.pdf?dl=0
invoice from admin looks a bit messed up, look at the total price table : https://www.dropbox.com/s/0w2pxgeytyc22t4/invoice-61.pdf?dl=0
- October 2, 2018 at 2:37 pm #33051
“Last test I did after last update everything looks 95% good,”
– Ahhh … great 🙂Actually, vendor is from WCFM and admin invoice is from PDF Invoice plugin.
You may even disable this, if your site will going to have only vendor’s product.
Actually, WCFM does not send out any invoice for admin’s product.Well, for admin invoice, I think it’s due to this template setting – https://ibb.co/dLUtKK
Try once with “Simple RTL”Thank You
- The topic ‘Store Invoice & Commission layout + translation issue.’ is closed to new replies.
