Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Store Location
- This topic has 6 replies, 2 voices, and was last updated 6 years, 8 months ago by
- December 31, 2018 at 5:21 pm #41834
Mike Moua
GuestHi team,
I have a question on the store location setting, I have set my Google map API key under the Admin marketplace setting but when I log in as a vendor and try to set the store location I got the message “This page can’t load Google Maps correctly” any idea of what might be the issue? Also, it would be great if you can implement a search topic in this forum so we can search for something that is already answered.
Thank you.
- January 1, 2019 at 2:31 pm #41893
Forum search option is here – https://wclovers.com/forums/
Well, kindly re-check your Google Map API key, possible it has some restriction issue. (http-https related may be!)
You may check our demo there is no such issue – http://wcfmmp.wcfmdemos.com/my-account/
- January 2, 2019 at 4:18 am #41964
Mike Moua
GuestThe map is working fine on my contact form and on the store page, I have checked all the setting on google and still doesn’t work on the store location setting
- January 2, 2019 at 4:43 am #41968
Well, this two maps has some basic difference.
One is for showing locations, where setting map is for finding an location.
Between, kindly try once with this API key – AIzaSyB2YeMKniOp8PvU2qPj99m7LTedKOEGYUM
- January 2, 2019 at 5:54 am #41973
Mike Moua
GuestHmm… your API is working, I am not sure what is going on now, is this the Maps JavaScript API?
- January 2, 2019 at 6:05 am #41977
Mike Moua
GuestFor some reason after tried your API, now I switch back to my API and it works!!!
Thank you. - January 2, 2019 at 7:51 am #41984
MemberThat’s strange!
- The topic ‘Store Location’ is closed to new replies.
