Durga Puja
03Day 13Hr 17Min 13Sec
Durga Puja
Store Location
Viewing 17 reply threads
    • #106769
      r_guayaquil
      How can i show the location map in the vendor store? And also to show in the store list page.
      do i need to install a plugin? I have enabled the capability for the vendor to show the map and i have the widget to show store location, but no luck.
      Thanks for the help!
    • #107212
      r_guayaquil
      Any help?
    • #107775
      Well, this is WCFM Marketplace core feature, no other plugin require for this.
      You just have to setup store location from Vendor Setting Panel – > Location – https://ibb.co/KbDpsrG
    • #107942
      r_guayaquil
    • #108665
      Add this line to your site to disable country field for this widget –
      add_filter( 'wcfmmp_is_allow_store_list_country_filter', '__return_false' );
    • #108785
      r_guayaquil
      thanks for the code.
      what is the shortcode to make the stores look like the image attached? I have this shortcode: [wcfm_stores theme=’classic’ map=””]
      I have also tried using theme=’simple’ but still no luck. I am using the flatsome theme.
      Thanks again!
    • #108826
      There are 3 types of store list page theme views, they are: simple, classic, compact.
      Attached screenshots of 3 types of theme views below.
      PFA….
    • #110758
      r_guayaquil
    • #110930
      Please share us your website login details. We need to check the issue.
      Please do share your website login credentials as private reply here.
    • #110986
      r_guayaquil
    • #111193
      The “SG Optimizer” plugin was creating the issue, I’ve deactivated it in your website and its working fine now.
    • #111248
      r_guayaquil
    • #111253
      r_guayaquil
    • #111293
      Please go to your wp-config.php file and replace “define(‘WP_DEBUG’, true);” with “define(‘WP_DEBUG’, false);”, the warning will go.
      The optimizer plugin is having some compatibility issue with our plugin.
    • #111330
      r_guayaquil
    • #111361
      I’ve added the below code to your child theme’s functions.php file:
      add_filter( 'wcfmmp_store_list_after_store_info', 'cus_wcfmmp_store_list_after_store_info', 10, 2 );
      function cus_wcfmmp_store_list_after_store_info( $store_id, $store_info ) {
      	echo '<p class="store-phone">' . get_user_meta( $store_id, 'url-de-tienda-online', true ) . '</p>';
      The url is displayed for each vendors in the store list page.
    • #111369
      r_guayaquil
      Thank you! You guys rock!
    • #111417
      You’re most welcome.
  • The topic ‘Store Location’ is closed to new replies.
