wcfm-santa
-364Day 00Hr -49Min -37Sec
wcfm-santa
Store Page Layout
Viewing 7 reply threads
    • #47998
      contact16
      Having a few issues with the vendor store page layout:
      1. We are seeing an ’empty tab’ on the right hand side of the tabs on the store page (please see screenshot). How can we get rid of this tab?
      2. We have made a couple of test badges and they are displaying below the Inquiry and Follow links/buttons. How can we get them to render under the vendor’s photo?
      3. If we put a store search bar in the vendor’s sidebar, on mobile it will show under the Products. How can we get the search bar to render above the products (NOT the entire vendor sidebar to show above the products)?
    • #48127
      *** those are not empty tab, empty space. Well, you may tweak that tab bar CSS as per your requirement from child theme’s style.scss
      *** That’s also CSS tweak.
      *** Please at this code to your child theme’s functions.php –
      add_filter( 'wcfmmp_is_allow_mobile_sidebar_at_bottom', '__return_false' );
    • #48300
      contact16
    • #48343
      I am really sorry, there was a misunderstanding.
      I thought, you are asking for easiest way to make those tweaks, so I suggested you to use CSS.
      Don’t worry, I will give you proper CSS/code for the purpose.
      3. The PHP you provide does EXACTLY what we asked NOT to do (in capitals in the original post!). We would like, as we said in the original post, ONLY the search bar to appear above the products on mobile not the entire sidebar.
      **** Well, this is not possible to place only one widget at top and rest at bottom!
    • #48479
      contact16
      Thank you for this. We’re still waiting for the CSS though.
    • #48531
      I will give you, please give me a bit time.
    • #48544
      – Please use this CSS for the purpose –
      #wcfmmp-store .tab_area .tab_links{ width: auto; }
      – Is this only for mobile version?
    • #48550
      We will change store header mobile in next update to – https://ibb.co/mvLBprw
      Hope this will fulfill your requirement.
  • The topic ‘Store Page Layout’ is closed to new replies.
