Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Store setting fields disappear from dashboard
- This topic has 11 replies, 3 voices, and was last updated 6 years, 11 months ago by
Bingal.
- September 26, 2018 at 9:01 pm #32644
jhweb
ParticipantHi, when I activate WCFM Ultimate for some reason some options diasppear from the vendor dashboard. As you can see in the attached screenshot when the vendor clicks store in the ssettings menu the fields for Seller info and shop description have gone. If I deactivate WCFM ultimate they return?
Any advise would be greatly appreciated as this is causing a problem for vendors.
JonAttachments:
You must be logged in to view attached files. - September 27, 2018 at 2:43 pm #32690
Can you please check at WCFM Capability once and be sure you didn’t OFF these fields from capability?
Also check at WC Vendors Pro capability, hope you didn’t disable these from there!
- September 27, 2018 at 3:26 pm #32701
jhweb
ParticipantHi, thanks for getting back to me. Everything is on. I have changed to a default theme in case that was the issue but still not working.
I can set you up an admin account if you would like to take a look?
Jon - September 27, 2018 at 3:49 pm #32705
This is no way related to Theme.
Yeah please, share me access details, I will take a look at it.
A demo vendor access as well.
- September 27, 2018 at 5:03 pm #32710
jhweb
ParticipantThis reply has been marked as private. - September 27, 2018 at 5:24 pm #32717
Thanks for all the details, we are looking into this.
- September 28, 2018 at 8:08 am #32759
jhweb
ParticipantThis reply has been marked as private. - September 28, 2018 at 10:50 am #32764
Sir, resolved!
Please take a look.
There was a capability check issue in WCFM Ultimate.
I have just fixed that in your site and we will add that in next update as well.Thank You
- September 28, 2018 at 11:18 am #32768
jhweb
ParticipantExcellent thats perfect, thank you 🙂
Jon - September 28, 2018 at 12:19 pm #32775
MemberYou are welcome 🙂
If you ever get a chance then please add a review for me – https://wordpress.org/support/plugin/wc-frontend-manager/reviews/
Between, did you checked WCFM own multi-vendor module – https://wordpress.org/plugins/wc-multivendor-marketplace/
- September 28, 2018 at 1:26 pm #32786
jhweb
Participant***** Review left. 🙂
- September 28, 2018 at 1:31 pm #32791
Bingal
GuestJust checked, thank you very much 😊
- The topic ‘Store setting fields disappear from dashboard’ is closed to new replies.
