Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Store Setup Customization Help
- This topic has 6 replies, 2 voices, and was last updated 5 years, 11 months ago by
- May 6, 2020 at 4:49 pm #127438
rohitxd
https://prnt.sc/sbisno – Hello I need to remove this part How can I do it??
https://prnt.sc/sbsx73 – I want to remove policies tab in here
https://prnt.sc/sbt4dq – I want to add a text in the seo tab and add the store name he entered in the seo title… Check Screenshot
https://prnt.sc/sbtga1 – After adding the default description (forum topic i made)< it doesn’t show some required fields… - May 6, 2020 at 10:28 pm #127619
If you want to completely remove store policy settings for vendors, go to WCFM admin dashboard >> Capability and uncheck Policies under Settings section. See here- https://imgur.com/sf647fo
Now to set the store name as SEO title, add the following snippet to your child theme’s functions.php. In case you do not have child theme then add code using this plugin – https://wordpress.org/plugins/code-snippets/-add_filter( 'wcfm_vendors_settings_fields_seo', function($field, $vendor_id) { if ( wcfm_is_vendor( $vendor_id ) ) { $store_user = wcfmmp_get_store( $vendor_id ); $shopname = $store_user->get_shop_name(); if ( empty( $field['wcfmmp-seo-meta-title']['value'] ) && $shopname ) { $field['wcfmmp-seo-meta-title']['value'] = $shopname; } } return $field; }, 10, 2 );To add the text blow SEO step title use this following snippet-
add_action( 'wp_enqueue_scripts', function() { if ( wcfm_is_vendor() && filter_input( INPUT_GET, 'store-setup' ) && filter_input( INPUT_GET, 'step' ) === 'seo' ) { wp_enqueue_script( 'seo_step_script', get_stylesheet_directory_uri() . '/custom.js', array( 'jquery' ) ); } } );You’ll also require to create this custom.js file inside your child theme folder and paste the following code in it-
jQuery( document ).ready( function ( $ ) { $( '<p class="seo_step_suggestion_text">If you don\'t know what to do just skip this step and you\'re good to go</p>' ).insertBefore( 'form' ); } );Alternatively, you can use an existing JS file with some minor tweaking in this code.
Let me know how this goes.
Thanks! - May 7, 2020 at 12:09 am #127684
rohitxd
ParticipantThanks your code work perfectly!
BUT
What about ,
https://prnt.sc/sbisno – Hello I need to remove this part How can I do it??and also https://prnt.sc/sc4cg0 – still after removing the policy thing, this appears while adding a product
- May 7, 2020 at 12:26 am #127691
Is this vendor is assigned to any group? I yes then you need to change the capability from that group. Group settings got higher priority over general capability settings. If you disable Policies capability then, Policy tab will not show to your vendors dashboard. It will be visible on your admin dashboard though!
Thank You! - May 7, 2020 at 12:56 am #127711
rohitxd
ParticipantIs this vendor is assigned to any group
NOPE! - May 7, 2020 at 2:46 pm #127949
rohitxd
ParticipantUmm hello?
- May 7, 2020 at 5:11 pm #128026
You are continuing two threads and applying code from both areas. Also you are mixing your requirements in both the tickets. This will definitely put your site in trouble. Unexpected behaviors are common in that case. You have overridden a template file as well which I was unaware of.
Please keep separate issues, in separate threads.
On the other topic, lastly you wrote “This code worked instead of that” – so now I’m not sure if the problem still exists or not.
Let me know.
Thank You!
