Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Store widget click
- This topic has 2 replies, 2 voices, and was last updated 6 years, 5 months ago by
nolas154.
- June 1, 2020 at 8:50 pm #137371
nolas154
ParticipantHi, I am using your store widget in my product page and I inser the logo of the store too following your instructions. It looks awesome, but i when my users click on it, a new tab is openned and is no ggod for the navigation experience.
Anyone can tell me how can I change this onclick option in order to the navigation will be in the same window and tab, please?
Anyway, I want to do several improvements and I need a custom budget. Can you tell how can i contact you for that?
You must be logged in to view attached files. - June 2, 2020 at 12:51 pm #137627
Sarmistha Chakraborty
add_filter('wcfm_shop_permalink_open_by',function($target){ return ''; },10);Try this code to your child theme’s functions.php
- June 2, 2020 at 6:41 pm #137723
nolas154
ParticipantPERFECT!!!! Thank you so much!!
- The topic ‘Store widget click’ is closed to new replies.
