Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Stripe connect for international marketplace
- This topic has 3 replies, 2 voices, and was last updated 5 years, 6 months ago by
- February 17, 2020 at 7:33 am #107406
Paul Aswad
For stripe connect, there are multiple ways of setting it up. They offer 2 services, one that allows for transfers between marketplace and vendors in the same geographical zone. The other allows for split payments between the marketplace and an international vendor.
Is it possible to use the international one?
- February 19, 2020 at 3:22 pm #107836
Please add this line to your site for the purpose –
add_filter( 'wcfm_is_allow_stripe_express_api', '__return_true' );
- February 20, 2020 at 11:20 pm #108080
Paul Aswad
With which plugin will this work? I am using Yithemes Stripe Connect Plugin.
Will this make it so everything can be done through Stripe Connect?
Best regards,
Paul
- February 25, 2020 at 1:01 pm #108675
MemberWell, Stripe Split pay is part of WCFM Marketplace core, no third party plugin require for this.
https://docs.wclovers.com/vendor-payment/
