Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Stripe error when signing up
- This topic has 25 replies, 2 voices, and was last updated 6 years, 4 months ago by
- April 21, 2019 at 10:43 am #58861
sdel_nevo
ParticipantHi Guys
We only use stripe split pay as our gateway
when a vendor goes through the membership signup process, at the Stripe screen, if they try and connect their account at this point they get the error “invalid_redirect_uri” is thrown.
But they can successfully connect with their stripe account from the store manager screen.
Many thanks
Steve
You must be logged in to view attached files. - April 24, 2019 at 8:19 am #59122
Well, if you want to allow Stripe connect from store setup widget, then add that url at stripe account as redirect as well.
Remember, you have already added Store Setting page URL. Just add store setup page URL there as well.
- April 24, 2019 at 8:30 am #59127
sdel_nevo
thanks for that, what would the URL be?
this is the working one
https://www.my-domain.com/store-manager/settings/
would I add
https://www.my-domain.com/store-manager/store-setup/
sorry to be a pain
Steve
- April 24, 2019 at 9:03 am #59138
sdel_nevo
ParticipantHi Guys
I have put this URL https://www.my-domain.com/wp-admin/index.php?page=store-setup\u0026step=payment
and
https://www.my-domain.com/store-manager/store-setup/ into stripe,
I get the same error on both
I can’t join up to stripe when going through the store set up but can from the store-management
do you know what the URL would be
Steve
- April 24, 2019 at 10:19 am #59172
sdel_nevo
ParticipantHi guys
now stripe is not working at all!!
getting this error on the vendor’s screen
Array ( [error] => invalid_client [error_description] => This application is not connected to stripe account acct_1Df9BLDeGKxNi9PH, or that account does not exist. ) Unable to disconnect your account pleease try again
as per the screenshot.
how do I put this right?
can we remove the stripe setup screens from the membership signup screens
it seems pretty broken to me to be honestSteve
You must be logged in to view attached files. - April 24, 2019 at 10:39 am #59178
Set this – https://www.my-domain.com/wp-admin/index.php?page=store-setup&step=payment
But do not remove this – https://www.my-domain.com/store-manager/settings/
it should be there all the time.Thank You
- April 24, 2019 at 10:47 am #59182
– Do you have deleted this connected account manually from Stripe account?
- April 24, 2019 at 10:47 am #59183
sdel_nevo
ParticipantHi Guys
when trying to add that URL after i have change “My-domain” to the correct value i get
You must provide a valid HTTP or HTTPS URI
in stripe
also
any vendor who had connected a stripe account now gets
when viewing the preferred payment method screen#
steve
- April 24, 2019 at 10:48 am #59184
sdel_nevo
No i didnt delete any connections from stripe
steve
- April 24, 2019 at 10:54 am #59188
sdel_nevo
is this account held in the database tables anywhere? I have no way of connecting this account or disconnecting it!!
there must be a way of removing this entry from the system from a table somewhere I have looked through them but can’t see which one it would be held in?
any ideas as I am stuck now!!
Steve
- April 24, 2019 at 11:26 am #59195
sdel_nevo
ParticipantHi guys
ok this is what happened after I added the URLs from reply #59138 into my admin stripe account, a test vendor tested disconnecting their stripe account
at this point, they got the errorArray ( [error] => invalid_client [error_description] => This application is not connected to stripe account acct_1Df9BLDeGKxNi9PH, or that account does not exist. ) Unable to disconnect your account pleease try again
now they are unable to re-join the stripe account or remove it, do i have to delete the account completely I can’t find any way of getting the stripe account to either disconnect or reconnect again
i can’t see any references to stripe in any table so i have no idea how to remove it
this account is no longer connected to my admin’s stripe account, and I have no way of manually creating it here either
Steve
- April 24, 2019 at 11:31 am #59198
sdel_nevo
WOW done it, found the references to the broken stripe account in the user mata table, I have deleted those
and the vendor can now reconnect the account šSteve
- April 24, 2019 at 11:53 am #59201
sdel_nevo
tested again with the URL https://www.my-domain.com/wp-admin/index.php?page=store-setup&step=payment added to stripe and I get the same error
this has been added as a new redirect URL, the default one is still set as the store manager
is possible to have two URL redirects?
or is it better to remove the payment screen from the membership setup wizard
Steve
- April 25, 2019 at 6:40 am #59315
– It’s off course possible to set multiple redirect URLs.
Please check this – https://www.loom.com/share/e910c808965b41579c349c2c5d78d5ff
- April 25, 2019 at 6:46 am #59319
sdel_nevo
ParticipantHi guys
Thanks for getting back
I added the url to the redirect list and have tried again, but keep getting the same error
Iām not sure why but test vendors are not able to connect to stripe at this point but can from the store management screens.
I will continue to try and update you
Steve
- April 25, 2019 at 8:50 am #59374
sdel_nevo
ParticipantThis reply has been marked as private. - April 25, 2019 at 9:01 am #59384
sdel_nevo
ParticipantThis reply has been marked as private. - April 27, 2019 at 8:15 am #59622
Why “&” change to “\00u26” ?
Hope you checked my test, it’s working perfectly – https://www.loom.com/share/e910c808965b41579c349c2c5d78d5ff
- April 27, 2019 at 9:58 am #59648
sdel_nevo
ParticipantThis reply has been marked as private. - April 29, 2019 at 6:14 am #59820
Please share Site Admin and a demo vendor account with me to check this once here – https://wclovers.com/woocommerce-multivendor-customization/
Is this possible for you to share Stripe account details as well?
- April 29, 2019 at 12:48 pm #59902
sdel_nevo
ParticipantThis reply has been marked as private. - April 30, 2019 at 11:58 am #60079
sdel_nevo
ParticipantHi Guys
Have you been able to take a look at this, I sent the details over as requested
many thanks
Steve
- May 2, 2019 at 9:25 am #60312
sdel_nevo
ParticipantHi Guys
Have you been able to take a look at this issue yet? I see you logged in to my site yesterday,
I know you guys are very busySteve
- May 2, 2019 at 12:08 pm #60373
sdel_nevo
ParticipantHi Guys
been looking at this the additional URL needed to be added to stripe is
https://www.my-domain.com/wp-admin/index.php?page=store-setup&step=payment and that has been added to my stripe account
but the error I’m getting when the test vendor click the connect with stripe button is
it appears that the “&” between the words setup and step is getting incorrectly encoded
doing some digging on google says it may be a JSON error
json is enabled on my web host, I’m running PHP 7.2
the test vendors can connect to stipe via the store manager after they have signed up, but this error occurs when they try and connect their stripe account when signing up on the site.
I’m worried that I will lose sign-ups if people get this error when trying to join the site
really sorry to keep bothering you
any ideas?I have disabled every plugin on my site excluding woocommerce and your plugins with no luck
Steve
- May 2, 2019 at 2:33 pm #60414
sdel_nevo
the issue is resolved,
I had to update the API on stripe and add a URL into the “Endpoints receiving events from Connect applications” in developers “webhooks”
with the same URL as the connect Redirect URLset both to
and it works
just in case anyone else has the same issue
Steve
- May 3, 2019 at 3:55 pm #60506
MemberGreat … thanks for the update š
- The topic ‘Stripe error when signing up’ is closed to new replies.
