Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Stripe Split paiement Error
- This topic has 9 replies, 2 voices, and was last updated 5 years, 8 months ago by
- November 6, 2019 at 3:24 am #90958
gwaldys
ParticipantHi :),
I contacted you a few weeks ago because I encountered errors on the payment (Stripe split paiement).
You advised me to update wcfm. I made the update but my clients still encounter the same error. It does not happen all the time.
Do you know where the mistake might come from?
The error :
Erreur lors de la création de l’enregistrement client avec Stripe : Invalid source object: must be a dictionary or a non-empty string. See API docs at https://stripe.com/docs’
Stripe Split Pay “Erreur” : Invalid source object: must be a dictionary or a non-empty string. See API docs at https://stripe.com/docs’Thank you in advance
- November 11, 2019 at 5:24 pm #91809
MemberWe are checking this.
Between, are you using Stripe SCA?
- November 12, 2019 at 11:34 pm #92061
gwaldys
No i didnt.
I did somes tests, and i think it’s a cache problem.
I used Fast Velocity Minify and when i stoped it, i havent the problem.
So , tested with Autoptimize and uncheck “use in order page”. But i have the same problem.
Do you recommend a cache module ?
- November 22, 2019 at 10:20 am #93383
MemberUse this caching plugin – https://wordpress.org/plugins/wp-fastest-cache/
- December 5, 2019 at 1:13 pm #96137
gwaldys
I re-open this topic because customers report the problem again.We thank, it was because of caches but we haven’t caches system in this moment.
Do you know where could the problem come from?
- December 7, 2019 at 2:04 pm #96436
Are you using Stripe SCA?
Between, what is your WCFM Marketplace plugin version?
- December 9, 2019 at 12:13 am #96625
gwaldys
I don’t use stripe SCA for the moment.
My version of “WCFM – WooCommerce Frontend Manager – Ultimate” is 6.2.7
- December 10, 2019 at 2:15 am #96795
gwaldys
ParticipantOh sorry, I read wrong. My version of WCFM Marketplace is 3.2.6
- December 10, 2019 at 4:13 am #96806
gwaldys
ParticipantOK my problem is the same as this topic : https://wclovers.com/forums/topic/stripe-error-invalid-source-object/
I solve my problem i think with the same modification
- December 10, 2019 at 9:44 am #96816
MemberOK, that’s great.
We will make this change in WCFM Marketplace core in coming update.
- The topic ‘Stripe Split paiement Error’ is closed to new replies.
