I recently started using Sequential Order Numbers https://woocommerce.com/products/sequential-order-numbers-pro for a new marketplace and it seems like WCFM marketplace supports it in some areas but not others.
Please see the screenshots, WCFM correctly displays the sequential custom order number when showing a new order but not when an order is updated. Same with ledger, it shows order using the sequential number but then the withdrawal request shows default Woocommerce assigned order number.
In the screenshots, MSA1061 is the sequential order number and 6853 is Woocommerce original order number for same order.
Could you check to see if these can be consistent with new sequential numbers?
You must be
logged in to view attached files.
