Template Override
Viewing 6 reply threads
    • #63581
      Jared
      Hi! We need to override some template file located in “wc-frontend-manager/templates” to use our own header (not default header.php but header-custom.php). On that page /vendor-membership/?vmstep=thankyou header was get by /wc-frontend-manager/templates/classic/wcfm-content.php file. It’s possible and how?
      Remind , we cannot just change header.php in child theme because we need to use header-custom.php on thank you page but header.php is what’s included by default in wcfm-content.php template
    • #63887
      For which page you want to override this ?
      WCFM Store Manager page or “Membership Thank You” page ?
    • #63962
      Jared
      Page that shows after Vendor Registration i mean.
      So maybe is Membership Thank You page too
      But exactly not the WCFM Store Manager page.
    • #64225
      You are are allowed to define custom thank you page and set at Membership Setting panel – https://ibb.co/xhBMt4m
      You are also allowed to change exiting thank you page content – https://ibb.co/PCHfqpK
      So, no need to override this template.
    • #67676
      guiasdechile.cl
      Hi, it is my first time over here…sorry by my english 😉
      well, I tried to setup the settings from setting in admin, but nothing is showing. The buttons do not function.
      Otherwise, logged like vendor using other username and password everything works. I’m using wilcity theme. Maybe it is not compatible with WCFM.
    • #67682
      guiasdechile.cl
      If really wilcity theme uncompatible, which other rich template like wilcity can you recommend me?? (not storefront from woocommerce)
      thanks in advance.
    • #67862
      wilcity theme incompatible – why you think so?
      https://wclovers.com/wp-content/uploads/2019/06/Screenshot_2019-06-14-Store-Manager-%E2%80%93-MassMarket.png
      – It’s blank due to something else.
      Either site has some PHP error – Please check at wp-admin -> WooCommerce -> Status -> Logs -> fatal_erros log -> is any error generated?
      Or, there has some JavaScript error in site – please check using Google Chrome Browser console.
      You may also share site access here – https://wclovers.com/woocommerce-multivendor-customization/
      I will resolve this for you.
  • The topic ‘Template Override’ is closed to new replies.
