Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Text color is "White" in "Shop Description" Entry field
- This topic has 6 replies, 3 voices, and was last updated 6 years, 3 months ago by
- April 29, 2019 at 9:30 am #59867
productsexport
ParticipantWhen the vendor enters their shop description in the “Shop Description” Entry field, the text color is white and invisible due to the white background. How can we change that to Black text?
Also the same entry field window is very small. Can you increase it and make it bigger so it becomes easier to write and edit. I know you can expand it but that is not convenient specially for vendors who are not savvy.
Also, when a vendor adds a new product, the windows for the Short and Long product descriptions have the same problems.
You must be logged in to view attached files. - April 30, 2019 at 1:32 pm #60088
productsexport
ParticipantThis is very URGENT, can you please help here? Fast support is highly appreciated..
- April 30, 2019 at 2:34 pm #60099
sdel_nevo
ParticipantHi sadoun
I had the same problem, I put this into the custom css and it appears to have worked for me
I’m using the flat some themesteve
/* Shop Text Area */
.js .tmce-active .wp-editor-area {
color: #000000;
} - April 30, 2019 at 9:51 pm #60128
productsexport
ParticipantThanks Steve. I have the Flatsome theme as well. I tried your suggestion but didn’t help in my situation. Since we both have the same problem, it could be something conflicting between the theme and the plug-ins. I hope to hear from the developers.. Since this is important for us.
You must be logged in to view attached files. - May 1, 2019 at 12:56 pm #60195
– This field is broken so you are getting this like that.
I think you have JavaScript error in your site, please check using Google Chrome Browser console.
- May 1, 2019 at 5:55 pm #60264
productsexport
ParticipantOk found the problem was a conflict with Autoptimize plug in. When I deactivated this plug in, the field is back to normal.
What other plug in we can use in place of Autoptimize?
- May 2, 2019 at 10:06 am #60342
You may use Autoptimize, but it require a special setup.
We will do this for you.
- The topic ‘Text color is "White" in "Shop Description" Entry field’ is closed to new replies.
