wcfm-santa
-364Day -19Hr -13Min -30Sec
wcfm-santa
The problem with the import of products WCFM-Ultimate
Best Multi Vendor Marketplace Plugin for WordPress Forums Product Vendors The problem with the import of products WCFM-Ultimate
Viewing 3 reply threads
    • #60849
      Auhouse.ru
      The problem with importing products from suppliers, the supplier has exported products from its source in a file format .CSV, imports its products and as a result 500 empty products in the list, how to fix it?
    • #61276
      What do you mean by empty products?
      Are those variations or CSV was not created properly!
    • #61310
      Artem
      Suppliers have products in files of different formats, XML, TXT, Excel, there are online services where you can convert any format to CSV format. After converting the file, import the CSV file. And at the end of the download file is in one place and a list of products seen empty products. Empty products I call the goods downloaded from the CSV file, where in addition to the title of the GOODS nothing else is loaded
    • #61739
      – Please check this converted CSV, I think it’s format does not match with WooCommerce Product Import CSV – https://docs.woocommerce.com/document/product-csv-importer-exporter/
  • The topic ‘The problem with the import of products WCFM-Ultimate’ is closed to new replies.
