Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › The product translation flow problem has recurred.
- This topic has 5 replies, 2 voices, and was last updated 7 years, 1 month ago by
- June 30, 2018 at 2:14 am #25673
nakedharmonix
In our case, the product translation flow problem has recurred from Ver.4.1.0 or later.Regards,
TK - June 30, 2018 at 10:33 am #25682
Can you give me a more details one this?
What you mean by “product translation flow” ?
- July 3, 2018 at 3:27 am #25812
nakedharmonix
ParticipantTranslation is not reproduced exactly.
Ex.
Currency calculation is not adapted.
¥ 64 (JPY) = 64 $ (USDThere are other problems as well.
- July 3, 2018 at 6:09 am #25816
This is not translation. This is multi-currency problem.
Between, are you getting this right at WC default reports page?
We are planning to make this plugin compatible with WCfM – https://codecanyon.net/item/woocommerce-ultimate-multi-currency-suite/11997014
As I found, this is the only plugin which works perfectly for WC reports.
- July 3, 2018 at 8:28 am #25823
nakedharmonix
Foreign exchange conversion is reflected normally on the product list page price.
However, in the graph of Home and the report page, the exchange is not normally reflected. - July 4, 2018 at 1:23 pm #25887
Is this multi-currency plugin compatible with WC backend reports?
- The topic ‘The product translation flow problem has recurred.’ is closed to new replies.
