Toolset Types custom field group not displayed
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM Toolset Types custom field group not displayed
Viewing 3 reply threads
    • #49431
      Chris8403
      Hi, I have just installed your plugin today on the understanding that it was compatible with Toolset Types (full version, not the free version).
      I have a field group that I use within Woocommerce with conditional fields depending upon the brand of a product for sale.
      In WCFM Add Product, I only See Description and Short Description.
      Is it possible to use the custom Field Groups of Toolset?
    • #49498
      Well, WCFM works with Toolset but WCFM Ultimate required, hope you already have that.
      Still, WCFM Toolset integration not yet work with all such conditional logics.
    • #53093
      csampson
      I have this now – is there no way to use conditionals at all?
      Can the custom fields be moved to the location of the description and short description?
    • #53133
      – We are working on this part!
      – Possibly, but require custom coding!
  • The topic ‘Toolset Types custom field group not displayed’ is closed to new replies.
