Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Tranlate the dashboard and the initial settings
- This topic has 3 replies, 2 voices, and was last updated 5 years, 10 months ago by
Sarmistha Chakraborty.
Viewing 3 reply threads
- April 27, 2020 at 10:27 am #123535
- April 27, 2020 at 1:29 pm #123592
Try this code to your child theme’s functions.php
In case you do not have child theme then add code using this plugin – https://wordpress.org/plugins/code-snippets/add_filter('wcfm_dashboard_welcometext',function($text){ $text = sprintf('Welcome to the %s Dashboard', get_bloginfo() ); //change the text as per your requirement return $text; },20); add_filter('wcfm_store_setup_complete_button',function($text){ $text = __( "Let's go to the Vendor Dashboard", 'wc-frontend-manager' ); //change the text as per your requirement return $text; },20);Thanks.
- April 27, 2020 at 6:54 pm #123723
jp2019
ParticipantOnly the second code it’s work well…
- April 27, 2020 at 8:33 pm #123772
Regarding Welcome text,
Did you already translate the text from WP dashboard -> Loco Translate -> Plugins -> WCFM – WooCommerce Frontend Manager ?Thanks.
