Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Translate the term "Wallet" for Terrawallet integration in withdraw option
- This topic has 9 replies, 2 voices, and was last updated 6 years, 9 months ago by
CommunityCorals.
- October 23, 2019 at 6:06 pm #88625
CommunityCorals
we had this request some month ago. The withdraw option “wallet” can not be translated. It is possible to translate it in “wc-frontend-manager-de_DE.po” but it has no effect. Also the update to latest terra wallet version didn´t help. Is it possible that it is hard coded some where?
Would be great if you could tell me how to translate this.
Dominique - November 5, 2019 at 4:18 pm #90765
Well, this string is not from WCFM so you can not translate this from WCFM translation file.
Are you able to translate “wallet” word in other areas?
You may use such snippet to add translation dynamically –
function wcfm_custom_0511_translate_text( $translated ) { $translated = str_ireplace( 'wallet', 'wallet', $translated ); return $translated; } add_filter('gettext', 'wcfm_custom_0511_translate_text'); add_filter('ngettext', 'wcfm_custom_0511_translate_text');Thank You
- November 5, 2019 at 10:11 pm #90903
CommunityCorals
ParticipantHi, thanks. I am talking about the wallet term in vendor payment settings. This is not a WCFM string?
Anyways – Where do I have to enter the translated term in the code please?
Dominique - November 5, 2019 at 10:13 pm #90904
CommunityCorals
ParticipantAttached the screenshot with “wallet” term.
You must be logged in to view attached files. - November 11, 2019 at 5:16 pm #91805
That term comes from wallet plugin, not from WCFM.
– Add your translated word here in the code – https://ibb.co/Mk0pyWd
- November 14, 2019 at 2:20 pm #92257
CommunityCorals
unfortunately it doesn´t do the job. Still the payment options say “wallet”. See Screenshot. Below the snipet I use.
$translated = str_ireplace( ‘wallet’, ‘Guthaben für Einkäufe’, $translated );
return $translated;
add_filter(‘gettext’, ‘wcfm_custom_0511_translate_text’);
add_filter(‘ngettext’, ‘wcfm_custom_0511_translate_text’);Attachments:
You must be logged in to view attached files. - November 22, 2019 at 11:32 am #93398
Add this code –
function wcfm_custom_0511_translate_text( $translated ) { $translated = str_ireplace( 'Wallet', 'Guthaben für Einkäufe', $translated ); return $translated; } add_filter('gettext', 'wcfm_custom_0511_translate_text'); add_filter('ngettext', 'wcfm_custom_0511_translate_text');Thank You
- November 23, 2019 at 3:17 pm #93612
CommunityCorals
ParticipantStill Wallet 🙁
- November 26, 2019 at 2:54 pm #94030
MemberI am debugging this in your staging site.
- December 2, 2019 at 1:35 pm #95474
CommunityCorals
ParticipantGreat, did you find the reason?
- The topic ‘Translate the term "Wallet" for Terrawallet integration in withdraw option’ is closed to new replies.
