Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › translated products does not appear in wcfm ultimate dashboard
- This topic has 6 replies, 2 voices, and was last updated 7 years, 5 months ago by
Bingal.
- March 5, 2018 at 6:26 pm #19887
Mohammed
Guesthello,
I bought the “WOOCOMMERCE FRONTEND MANAGER – ULTIMATE” plugin and I have a website that has two languages: Arabic / English(default) , and I used WPML plugin for translations.
I just notice that the products in vendor dashboard does not appear in Arabic, and I am not sure what is the problem, I have checked links of the dashboard and the translations of the products but I could not find what is the problem, hopefully it is not a technical issue in the plugin. - March 6, 2018 at 6:40 am #19893
Bingal
Can you please know me one thing, which multi-vendor plugin you are using in?
Don’t worry, this is WPML configuration issue.
- March 6, 2018 at 10:11 am #19912
Mohammed
GuestHi Bingal,
I am using WC-Vendor Pro plugin
thanks for the quick respond.
- March 6, 2018 at 10:35 am #19913
Bingal
Thanks for the info.
Can you please know me what is language setting for WPML?
Please be sure, you are using directory for each language. “?lang=*” option will not work for the case.
- March 6, 2018 at 11:13 am #19916
Mohammed
Guesthi,
The language URL format that I use now is (Different Languages in Directories) and I use directory for the default language which is English
- March 7, 2018 at 7:49 am #19933
Mohammed
Guesthi @bingal
still waiting
- March 7, 2018 at 6:03 pm #19955
Bingal
KeymasterThis issue has comes due to Arbic translation, “enter” pressed after each translation strings.
Closing this here for now.
- The topic ‘translated products does not appear in wcfm ultimate dashboard’ is closed to new replies.
