Black Friday
03Day 12Hr 17Min 55Sec
Black Friday
Translation issue
Viewing 3 reply threads
    • #121970
      stzi
      All,
      with a translation file active we suddenly see the same wording twice in the vendor dashboard. (see in screenshot attached)
      In Dashboard -> Orders -> Header line (where you can select by status) we have the same status twice.
      At the same time in the admin panel the status (and translation) is correct.
      Thanks for your support,
      Stefan
    • #122133
      For translate please use Loco Translate plugin(https://wordpress.org/plugins/loco-translate/). For documentation : https://localise.biz/wordpress/plugin/beginners
      Changing Dashboard -> Orders -> Header line,
      WP dashboard -> Loco Translate -> plugins -> WCFM – WooCommerce Multivendor Marketplace -> select your language(or create your language) -> search string(like “Pending”) & translate
      WP dashboard -> Loco Translate -> plugins -> WooCommerce -> select your language(or create your language) -> search string(like “Pending payment”) & translate
    • #122297
      stzi
      Dear Sarmistha,
      We already had all the translations done. Howevercwe followed your instructions again with the same result.
      The correct translation is not fetched in the vendor backend.
      Thanks for your help.
      • #122477
        Have you translate using “Loco Translate” plugin? We have tested in our local server, and its working perfectly.
        Please Try this code in your theme’s functions.php
        function my_text_strings( $translated_text, $text, $domain ) {
        	switch ( $translated_text ) {
        		case 'Pending' :
        			$translated_text = __( 'Zahlung ausstehend', 'woocommerce' );
        			break;
        	return $translated_text;
        add_filter( 'gettext', 'my_text_strings', 20, 3 );
        WP dashboard -> Loco Translate -> plugins -> WCFM – WooCommerce Multivendor Marketplace -> select your language(or create your language) -> search string(like “Pending”) & remove the translation and save.
    • #123378
  • The topic ‘Translation issue’ is closed to new replies.
