wcfm-santa
-364Day -13Hr -16Min -49Sec
wcfm-santa
Translation issues
Viewing 4 reply threads
    • #37310
      I’m working to translate WCFM in french and I encountered some issues.
      In the payment settings for the vendor, the strings are not translating.
      I attached a screenshot for you to see.
      I am using LocoTranslate and I synced the template, then the french translation made by you and finally my own custom translation.
      All the other strings are translating well.
      Can you take a look at that please ?
      Regards
    • #37312
      Please check this – https://ibb.co/eKs25V
      This strings are from WC Vendors translation, please check WC Vendors French translation file.
    • #37327
      Thanks I managed to translate the string above but for a strange reason the string “Account Type” for Mangopay is not translating and I don’t know why.
      I attached another screenshot.
      The mangopay file is correctly translated because in the admin page it is translated.
      Regards
    • #37331
      I understand why it’s not working properly.
      Mangopay has changed this label later – https://ibb.co/e4LLsA
      We will add this in WCFM translation in next update.
    • #37417
      WCFM 5.1.10 has just released, kindly update yours and sync your translation file with this.
  • The topic ‘Translation issues’ is closed to new replies.
