wcfm-santa
-362Day -13Hr -32Min -19Sec
wcfm-santa
Translation problem
Viewing 5 reply threads
    • #32647
      nakedharmonix
      I am setting up WCFM in English because I am building a multilingual site by WPML.
      But,Menu manager and Dashboard Pagesslug settings are automatically unintentionally translated to Japanese.
      I’ll fix it, but that will repeat.
      https://prnt.sc/kz6a2b
      https://prnt.sc/kz6a8k
    • #32698
      Are you seen these terms in Japanese when you are browsing site in Japanese or in English?
    • #32711
      d-n-13
      Did you save the menu manager in your 2nd language ?
    • #32827
      Well, WCFM menu manager does not work for different languages.
      You have to translate menu labels using “WPML String translation”.
      Menu URL auto detect by WCFM, no need to separate for different languages.
    • #32864
      d-n-13
      Hi @forum_wclovers
      Maybe it will be good idea to Disable / Hide Menu Manager in other languages ? enable for default language only.
      I see many do the mistake
    • #32940
      Actually, we will disable total setting panel for other languages.
      None of the setting can not be translated so it has no meaning.
      Will add a message for other language – “Browse using basic language to access setting options!”
  • The topic ‘Translation problem’ is closed to new replies.
