Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Translation product setting confusion
- This topic has 10 replies, 2 voices, and was last updated 7 years, 11 months ago by
- July 18, 2018 at 10:32 am #26507
nakedharmonix
ParticipantHI
It has some problems in adding new products from the different from site base language side.Basic condition
・Base language: Japanese
・Other language: English■ Problem: 1
1: Add product
New product add from English side.2: Translate to Japanese (click translation icon)
English page -> Japanese page (Ja copy)*Writing to the database has been completed but page migration is not done. It times out.
*New product addition notification e-mail is not sent.
■ Problem: 2
1: Add product
English page -> Japanese page (Ja copy)3: Move to English page again (click icon)
Japanese page (Ja copy) -> English page (en copy) (en copy)*Create a new translation page that do not need.
- July 22, 2018 at 5:49 am #26691
I think problem is here -“*Writing to the database has been completed but page migration is not done. It times out.”
Kindly check at wp-admin -> WooCommerce -> Status -> Logs -> is there any error related to this? Most of this time it through memory issue errors.
- July 26, 2018 at 5:17 am #26948
nakedharmonix
ParticipantI did the same test at the WCFM demo site.
http://wcfmgs.wcfmdemos.com/ja
The same problem is also occurring at WCFM’s demo site.After adding products to languages other than the basic language, if translated into the base language, it will not replicate properly and timeout
Example)
Basic language: Japanese
Other language: English1: Product added on the English side
2: Translation of goods into Japanese> Can not being successfully duplicated>Timeout - July 29, 2018 at 5:01 am #27066
WCfM 4.2.3 and Ultimate 4.2.2 has just released.
Can you try this once with WCfM latest update?
- July 30, 2018 at 5:44 am #27226
nakedharmonix
Translated timeout of wcfm has been improved.
However, there is an error in the reflection data in the wpml database.
(Table name: icl_translations, column name: source_language_code)
Initial language) ja
Second language) enIt is a case where product registration is done from the second language (en) and translation to the initial language (ja) is done.
In processing from the back end, source_language_code is “en”.
In case of wcfm, source_language_code is “ja”.Is not this a violation of WPML specification?
Regards,
TK - July 30, 2018 at 5:57 am #27227
nakedharmonix
ParticipantThis reply has been marked as private. - July 30, 2018 at 5:05 pm #27265
Thanks for the detailed description.
I will check this, is this any how problematic for WPML or not?
Causing any issue or not!Thank You
- July 31, 2018 at 6:50 am #27314
nakedharmonix
As of now, we can not confirm the problem with WMPL HOOK.
Additional Question.
Was the metadata processing method changed in ver 4.2.2?Regards,
TK - July 31, 2018 at 7:53 am #27335
No, nothing change for meta data.
Are you getting any issues regarding this?
- July 31, 2018 at 8:03 am #27338
nakedharmonix
ParticipantHI
Our problem on WCfMu – 4.2.2
When product was saving in second language.
The second language product metadata overwrites the basic language metadata.Regards,
- July 31, 2018 at 8:06 am #27340
Well, you are talking about this, right?
“However, there is an error in the reflection data in the wpml database.
Second language) en”We are checking this!
- The topic ‘Translation product setting confusion’ is closed to new replies.
