Translation with loco translate is not completed?
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate Translation with loco translate is not completed?
Viewing 4 reply threads
    • #114710
      modemradio
      Hello
      I do not understand why certain elements are not translated.
      I used the loco translate extension and created .po files
      That translated well 3/4 but as in the example in screenshot untranslated when everything is 100%
      thank you in advance
    • #114739
      SebastianFloKa
      … are you sure you pressed the sync button in loco translate each time?
    • #114740
      modemradio
      No
    • #114774
      SebastianFloKa
      … and does it work if you press the sync button in loco translate? Also, it’s recommended to choose for the location of the files the “custom location of loco”, even this is probably not causing your issue. There are several explanations how to use loco translate, I personally think the following one is quite helpful for example:
      https://localise.biz/wordpress/plugin/beginners
    • #114806
      modemradio
      thanks
  • The topic ‘Translation with loco translate is not completed?’ is closed to new replies.
