wcfm-santa
Wishing you joy this Diwali and Halloween! Enjoy up to 20% off on all addons!
02Day 18Hr 53Min 24Sec
wcfm-santa
Two problems!
Viewing 14 reply threads
    • #47080
      vraugul1
      Hello, I bought a license “Ultimate” and “Group & Staff”
      I have two problems.
      Tell me how to solve them.
      1. When registering a Vendor Store, in the line “Store Name” when I write the name in Russian letters, it gives this…”%d1%80%d1%83%d1%81%d1%81″
      The screenshot shows.
      And when I click “VISIT” in [wcfm_store], the store page doesn’t open.
      How to fix?
      2. How to remove “header” and “page-footer” on a particular store page?
    • #47152
      vraugul1
      During registration, no “user_nicename” is created in the database, and the store page is not created on the vendor.
      If you write manually for example “5”, then the link will appear “https://naenote.ru/vendor-stores/5/”
      How to fix it?
      Thank!
    • #47167
      All problems comes due to “Non English” store name.
    • #47168
      vraugul1
      How to fix this?
      The site is in Russia, and the names of the shops are Russian.
      Please help me.
      Thanks for the quick response!
    • #47185
      Understand, only solution will be – Store name can be in Russian, but not store slugs.
      Please add this code to your child theme’s functions.php –
      add_filter( 'wcfm_generated_store_slug', function( $store_slug ) {
      	global $WCFM, $WCFMvm, $wpdb, $wcfm_membership_registration_form_data;
      	if( isset( $_POST['wcfm_membership_registration_form'] ) ) {
      		$wcfm_membership_registration_form_data = array();
      		parse_str($_POST['wcfm_membership_registration_form'], $wcfm_membership_registration_form_data);
      		$wcfmvm_registration_static_fields = get_option( 'wcfmvm_registration_static_fields', array() );
      		$is_user_name = isset( $wcfmvm_registration_static_fields['user_name'] ) ? 'yes' : '';
      		if( !$is_user_name ) {
      			$user_email = sanitize_email( $wcfm_membership_registration_form_data['user_email'] );
      			$username   = sanitize_user( current( explode( '@', $user_email ) ), true );
      			$append     = 1;
      			$o_username = $username;
      			while ( username_exists( $username ) ) {
      				$username = $o_username . $append;
      				$append++;
      			$wcfm_membership_registration_form_data['user_name'] = $username;
      		$store_slug = $wcfm_membership_registration_form_data['user_name'];
      	return $store_slug;
      add_filter( 'wcfm_is_allow_store_slug', '__return_false' );
    • #47186
      vraugul1
      This code helped, Super!
      You are the best!
      Thank you for your plugin and technical support!
    • #47187
      vraugul1
    • #47193
      You are welcome 🙂
      – Well, CSS will be best for this purpose.
    • #47198
      vraugul1
      Where can I find the css of this page?
      What is the principle (template) to create a store page?
      Why in” header ” written blog?
    • #47199
      vraugul1
    • #47211
      Please add this CSS to your site –
      .wcfmmp-store-page .page-title, .wcfmmp-store-page .woodmart-prefooter { display: none !important; }
    • #47212
      vraugul1
      You really are the coolest!
      Thank you for the best technical support!
    • #47213
      vraugul1
      Can you tell?
      Can me in another subject write?
      https://wclovers.com/forums/topic/filter-by-groups/
    • #47214
      We are checking that.
    • #47219
      vraugul1
      Good
  • The topic ‘Two problems!’ is closed to new replies.
