Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Unable to import variable products from vendor dashboard
- This topic has 17 replies, 2 voices, and was last updated 6 years, 4 months ago by
- March 9, 2019 at 9:34 am #51711
neelesh.pednekar
I’m unable to bulk import variable products from the vendor dashboard. I have the WCFM Ultimate.
It creates individual products for each variation as well as the master product.
I’m trying to import 2 variable products with 3 variations each.
Here’s the sample file https://drive.google.com/file/d/1gtG_BFKULvycFZpNpNbpH-_Zuk-23ftn/view?usp=sharing
It works perfectly when I’m using it from the WP Dashboard (for Admin).
Please suggest.
You must be logged in to view attached files. - March 10, 2019 at 5:48 am #51801
Please re-validate your csv once with WC standard – https://docs.woocommerce.com/document/product-csv-importer-exporter/
- March 11, 2019 at 7:43 am #51968
neelesh.pednekar
This sample file is downloaded from the above link itself.
The format is correct, it is importing the products. The issue is when I import it from the WP-Admin it imports as 2 products with 7 variations, when I upload it from WCFM it uploads as 9 individual products.
Thanks and Regards,
Neel - March 11, 2019 at 8:55 am #51984
MemberOK, that’s strange!
We are checking this.
- March 12, 2019 at 5:29 am #52198
Can you please share your CSV with us to check this?
We have tested using this WC Standard CSV and it’s working perfectly – https://docs.woocommerce.com/wp-content/uploads/2017/06/dummy-data.csv
- March 12, 2019 at 7:56 am #52217
neelesh.pednekar
I tried importing only variable and variation products from your shared link (above).
It imports 6 products from the vendor dashboard when it is ideally supposed to import only 2 and rest need to be set as variations.
The variable products show (out of stock) when in Stock is marked as 1.
When I run the same import from the Administrator dashboard, it imports the product perfectly with variations.
I’m attaching a file with the screenshots.
You must be logged in to view attached files. - March 12, 2019 at 8:48 am #52232
– I understand the issue, it’s because “Product Publish” disable for this vendor.
We will take care of this in next update.
- March 12, 2019 at 9:04 am #52235
neelesh.pednekar
ParticipantAwesome. Thanks.
By when can we expect the update or can you roll out some fix in the meanwhile.
Cheers!
- March 12, 2019 at 12:28 pm #52269
It will be there end of this week.
- March 22, 2019 at 3:26 pm #54027
neelesh.pednekar
The update has not yet fixed the issue?
It’s still importing multiple products when I import from the vendor while imports only 1 with 9 variations when I import form the admin.
File attached.
Thanks and Regards,
Neelesh R PednekarAttachments:
You must be logged in to view attached files. - March 23, 2019 at 11:28 am #54160
This has been resolved, please be sure you have updated WCFM Ultimate to 5.4.6 as well.
- April 1, 2019 at 11:51 am #55581
neelesh.pednekar
This is still not working.
Current version – 6.0.0
The products are imported properly from the Woocommerce product import screen however each variation is imported as a single product from the vendor dashboard.
Attached is the file
Thnaks and Regards,
You must be logged in to view attached files. - April 6, 2019 at 4:40 pm #56516
Kindly WCFM Ultimate 6.0.1 and check once.
- April 8, 2019 at 10:21 am #56818
neelesh.pednekar
Updated and tried.
No luck.
- April 8, 2019 at 10:27 am #56824
neelesh.pednekar
ParticipantHere are my store settings for your reference.
You must be logged in to view attached files. - April 10, 2019 at 10:52 am #57095
MemberDo you have updated WCFM Ultimate?
- April 10, 2019 at 3:00 pm #57171
neelesh.pednekar
Just received the updated. Tried and now it works fine.
Cheers guys!
Neelesh R Pednekar - April 11, 2019 at 4:52 pm #57304
MemberGreat … thanks for the update 🙂
- The topic ‘Unable to import variable products from vendor dashboard’ is closed to new replies.
