Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Unable to upload product images
- This topic has 5 replies, 2 voices, and was last updated 5 years, 11 months ago by
- May 14, 2020 at 3:51 am #130716
SABRINA SIMMONS
ParticipantVendors are unable to upload product images. I’ve disable everything plugin and the issue is still there. Please help as soon as possible. It’s been more than a few weeks now. Thanks
- May 14, 2020 at 3:51 am #130717
SABRINA SIMMONS
ParticipantI disabled every plugin and I am still having the same issue “Unexpected error occurred”
- May 14, 2020 at 3:52 am #130718
SABRINA SIMMONS
ParticipantThis reply has been marked as private. - May 14, 2020 at 4:39 am #130734
SABRINA SIMMONS
ParticipantIf the vendor logs in, tries to upload an image, then logs out, and then logs back in they are able to upload images. But if they login and don’t log out, they are unable to upload images.
- May 14, 2020 at 5:04 am #130738
SABRINA SIMMONS
ParticipantThis reply has been marked as private. - May 14, 2020 at 8:39 am #130778
Please share the link where I can get this behavior, I have checked your website but could not find the login popup? Is the popup coming from your theme? Does reloading the page after login (via popup) solves the issue?
Also, follow this link https://wordpress.org/support/article/using-your-browser-to-diagnose-javascript-errors/ to determine if there is any console error generated after your vendors logged in (via popup). You can further check wp-admin -> WooCommerce -> Status -> Logs -> fatal_erros log for any serverside errors.
Let me know what you find out.
